part number for brass nipple for BCUii
  • part number for brass nipple for BCUii
    Hi, Am looking for a part number for the brass fittings for the end of the pneumatic pipes for the BCUii used for the Durabowl system. I had one that sheared and can't find a part number for it....
    it's the threaded end that puts air into the BCUii rather than the end that puts pressure through to the actual bumpers....
      This is confusing. Don't know what you mean by 'puts air into the BCU'. Can you post a picture of what you're looking for?
      Regards,
      Billy T
      bthompson@qubicaamf.us
        not air into the bcu itself. hope to get a pic up tomorrow. basically the valves (IN/OUT) from where a compressor would be hooked up. the backboard the bcu is connected to.
          If you take a nipple to a plumbing supply place or a heavy truck dealership that has air brake parts you can probably find one locally.
            Hope the photos help. The brass nipple attaches to the loose end of the hydraulic hose and then screws in where the "in" label is visible on the valve to the right of the BCUii. I'll try a plumbers merchant but would still very much like a part number for this......
              10-32 UNF 1/4 Tube Quick Conn
              Were you able to get the rest of it out of the solenoid? If not, the solenoid is 049007123
              Regards,
              BillyT
              Regards,
              Billy T
                it took me a while but i got the snapped thread out. thanks for that part number - very helpful.
                  managed to get one sent express delivery. should have it tomorow or Saturday. thanks again for the help.
                  Detector Rod Adjustment
                  The New Brunswick NXT
