Bruswick is no longer selling plastic gears for Pinball wizard motors!
  • Bruswick is no longer selling plastic gears for Pinball wizard motors!
    So instead of replacing the gears (17-200159 ,17-200160 ) we have to buy new motors or...does anyone know a alternative source?
    Probably just redesigning them and superseding the part #. What does Brunswick say?
      The part is discontinued and is no longer available. The only option now is to replace the whole motor assembly. Chief
        Actually i am looking at 3 d printed gears. Have guy making both internal gears out of 2 different materials. one material is supposedly stronger than the other. Waiting for them so i can install and test with weight
        Ignorance is Bliss!
        Qubica BES-X Lane Advertising
        Ball Damage at my wits end
        GS-X table bolts/stud
        Other that...
        1:1 shaft wear
