my qubica controle panel looks to have died on me have power going to it but have no lights and won't beep what elsa can I check or how can I go around it to get them to go up and down
qubica bumpers controle panel
by BrunoHello the guys,
I must install soon for a friend of the durabowl automatic bumper AMF with an automatic system of marking Qubica of 1998.
On the handbook of Qubica...-
Channel: Qubica Scoring Systems Discussion
01-23-2007, 05:10 PM -
by onkiHi all!
I have QBump II installed and want to install them on additional lanes - for me, QBump II ist the best system I have ever seen.
So - I already...-
Channel: Bumper Bowling Equipment
02-27-2018, 01:42 AM -
by ben87Hi guys,
We've been having a problem with the bumpers on some of our lanes recently. We're using PW bumpers interfaced to our qubica/amf scoring system via a BCU-BRU...-
04-13-2011, 12:41 PM -
DOES ANYONE OUT THERE HAVE QUBICA GUTTER BUMPERS
VERSION 1, THESE ARE POLYMER GUTTER'S SPLIT DOWN
THE CENTER AND RAISED OR LOWERED BY AN AIR COMPRESSOR. WE PURCHASED...-
12-05-2001, 01:05 PM -
What does ever one think of Qubica... Do you like it or not.
12-23-2004, 04:21 PM -
Bind in deck hook linkage
GS-X table bolts/stud
Other that...
Other that...
