Ace Mitchell Refurb?
  • Ace Mitchell Refurb?
    I read about Ace Mitchell refurbishing Phoenix machines. Does anyone know what they do, or cost? Do they come to you, or do you send your machine in to them?
    My machine is 17 years old, and still runs, but I think it may need some TLC.
    John
    It can be done either way. But having Jason redo your manchine will be the best investment you'll make in a long time.
    Cloth: ShamWow!
    Machine: Johnny 5
    Table support assembly
    Foul Light LED Mod
