Crossfire cam index error
  • Crossfire cam index error
    got a Crossfire machine that stopped today when cleaning and oiling the lanes.
    It stops after a few feet and different for different patterns i try to use.
    error message is cam index error.
    If i set clean only cleans and run normal but cleanandoil or oil IT stops with error.
    I checked cam in test menu but IT seems to work normal.
    so i think the cam motor is still working.
    Forgot to check fuse but check that tomorrow.
    Anyone GOT the same problem.
    Problem solved. Was a bad contact on a wire. Cleaned and now wokring again.
    Haven't actually done any welding for years, so I was up to the challenge when I found this machine that was having problem setting the head pin.
    Someone had welded this...
    Foul Light LED Mod
