Kegel Squeegee Up Error Message
  • Kegel Squeegee Up Error Message
    I'm having a problem with my Kegel Kustodian Plus lane machine. I keep having error message S9 (Squeegee Up Error). Any ideas on what it could be? I already switched the motor. That was not the problem. If I do the test output #11, it sometimes doesn't want to work. It makes a clicking sound when I try the test output. Any suggestions on what to try? Thank you!
    It could be a microswitch problem or the squeegee could be adjusted to high via the threaded rod.
    Detector Rod Adjustment
    The New Brunswick NXT
