Phoenix S
  • Phoenix S
    I NEED TO KNOW WHICH RELAY ON THE BOARD IS FOR THE SQUEEGEE I KNOW ITS 203 BUT ON THE BOARD YOU HAVE A ROW OF 4 ON 1 SIDE AND I BELIEVE 6 ON THE OTHER. I'M THINKING ITS THE 2ND ONE WITH THE ROW OF 4. THE LITTLE BLACK RELAYS I'M TALKING ABOUT. MY SQUEEGEE EVERY NOW AND THEN WON'T STOP KEEPS GOING UP AND DOWN I CALLED IN SAID IT WAS PROBABLY THAT RELAY. THINKING IT WOULD JUST HAVE 203 ON IT BUT NOPE SO NOW I STUMPED. THANKS
    There is a little numbers (from 0-11) with a box around it on the board, look for the 3, however the constant running up and down of the squeegee indicates a loss of the input for the up and down switches. Make sure your input module is seated properly, its the first module on the left.
    Television is called a medium because it is neither rare or well done.
    Broken key
    Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
    Anyone wanting to have a guess at
    A) Which...
    MONITOR COLOR ISSUE!!
    Pin spot is off
    4" PVC BOW EXTENDERS
    As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
