Kustodian Walker B Big Issues A7 error no movement
  • Kustodian Walker B Big Issues A7 error no movement
    A7 error E Stop circut breaker melted Drive Board flashing Stop error code machine wont move
    If your Estop CB is melted, that should be the first place to start tracing back to why. Loose connections in charging circuits will cause meltdowns, so when replacing the switch assembly, verify ALL the connections throughout the power circuit are secure. You won't likely get anywhere else until that part is figured out. While checking things, make sure all the other glass fuzes are intact as well.
    MONITOR COLOR ISSUE!!
    Pin spot is off
