Crossfire 6 pad camshaft
  • Crossfire 6 pad camshaft
    Hi guys,
    I would like to know if I was to order part number 158-6233 which is the camshaft for the 6 pad crossfire, is that a complete assembly with the 6 cams or do they have to be ordered seperately ?
    thanks ,
    Brett.
    Contact the supplier.
      158-8206 should be the cam shaft complete with cams for a 6 pad machine.
      Technical Manager
      Bowltech UK Ltd
      www.facebook.com/ross.gibson
      Warning: The above post may contain sarcasm,
        Turns out the venue in question has the 8 pad configuration.
        Any idea if that can be bought as a complete Assy?
          158-8206A should be the 8 pad cam assembly.
          Technical Manager
          Bowltech UK Ltd
            Thanks mate appreciate it
            Detector Rod Adjustment
            The New Brunswick NXT
