Kegel Flex Walker Cleaner Tip Leaks
  • Kegel Flex Walker Cleaner Tip Leaks
    Evening everyone!
    I have a Kegel Flex Walker. When the machine sits for a period of time in the approach (waiting to oil more lanes or for bowlers to finish up on the next pair) the cleaner head keeps dripping. It also keeps dripping to the point where it can cause a decent sized puddle underneath the machine. Any tips on how to fix that leak or does the cleaning head need to be replaced? Got it in 2015 and I think its still the original cleaner head.
    Thanks!
    It could just be a cracked tip. Being plastic it's prone to crack when bumped when cleaning the machine.
    Another cause is a bad hose connection or split in the hose.
      If it does it with power off and power on it may be what James said.
      If it is with power on only then you may have the cleaner pump creeping which is quite common
      You need to locate the min pot on your cleaner speed board and turn it down slightly to see if this stops it.
      Technical Manager
      Bowltech UK Ltd
      www.facebook.com/ross.gibson
      Warning: The above post may contain sarcasm,
        I ended up replacing the cleaner tip. I am pretty sure the valve went bad. No dripping since then. Thanks!
        Broken key
        Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
        Anyone wanting to have a guess at
        A) Which...
        MONITOR COLOR ISSUE!!
        Pin spot is off
        4" PVC BOW EXTENDERS
        As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
