Envoy won't return
  • rgarcia
    started a topic Envoy won't return
    Envoy won't return
    I have a Brunswick Envoy Lane machine and have ran into a issue with it not returning once it reaches the pit. There is no error message. Listening to the machine I can hear that it does not pick up the duster cloth like usual before its return. I have checked and cleaned the end of lane sensor and it seems to be okay. Thanks.
  • loadtoad
    Thanks for the good corrective action description.
  • rgarcia
    After troubleshooting and eliminating the end of lane sensor as the issue I went onto the end of lane speed adjustment. Page 79 of the Envoy Lane Machine manual walked me through what to look for and how to correct it. The back of the machine was not reaching ~2" past the 2-3 pin spots. I had to increase the End of Lane Speed Adjustment +4 to get it to the correct position. Problem fixed.
  • Wookie8662
    I would still suspect the end of lane sensor.
    Check your height and sensitivity adjustments.
  • rgarcia
    It just stops at the end of the lane.
  • Pinchezr
    Does it run into the pit?
    Or does it just stop at the end of the lane?
Broken key
Recently had to overhaul a Jap A2 gearbox. I found this shattered key to be the cause of the problem.
Anyone wanting to have a guess at
A) Which...
MONITOR COLOR ISSUE!!
my appologies if Ive posted this in the wrong area, this is my second post on this site, Ive got a 10 lane center ( 5 pairs ) and on lanes 3&4, I am having a problem with...
Pin spot is off
I'm currently working at a 38 Lane center. Of those 38 lanes only a few are having this issue.
I'm currently trying to get all the lanes to have perfect pin spots...
Idler shaft
One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
4" PVC BOW EXTENDERS
As requested a couple pics and detail of my setup. I started installing these 2 years ago after I got tired of those rubber hose extenders that would just bend. I watched and...
