Kustodian C oil tip question
  • Kustodian C oil tip question
    When the oil tip ends left and right the holder it rides in smacks the inside in the machine fairly hard. Enough so that indents are starting to form in the metal where it stops.
    Is there a way to slow or cushion the blow ?
    There's an electronic kit upgrade you can get for the Original K to stop the characteristic knocking of the oil head.
      Thanks James . I have a tech coming in august to do some relay and programming upgrades . I though he had said it would fix this issue.
        There are proximity sensor upgrades for the oil head, and lane distance wheel.
        It will still knock a bit, it just wont crash into the sides.
          The tech came and did the upgrades last month. he changed a capacitor to a different value . No more slapping .
          Qubica BES-X Lane Advertising
          Ball Damage at my wits end
          GS-X table bolts/stud
          Other that...
