Phoenix 8-pad Cleaner Pump
  • Phoenix 8-pad Cleaner Pump
    I was wondering if someone who has this machine could post the specifications for the DDP 5800 cleaner pump on the Phoenix 8-pad machine. The label on mine has almost completely washed away. There should be numbers for amperage, GPM, PSI, and Bypass. Thank you!
    82-70 MP Pinsetters+Humpback/Light Ball Clutch/Rocket Rails
    *Monitor repair for Steltronic Elex/SuperElex system! Send me PM!
    Send me your email on private message. I can give you what you need
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
