Silver Bullet Magnum will not engage
  • Silver Bullet Magnum will not engage
    Hi Guys,
    Have a AMF Silver Bullet Magnum that will not engage after pressing the button on the handle. The power is fine on the machine... the screen comes up and shows no faults or errors. When we press the button to start the machine to go down the lanes, nothing happens. I am thinking it's a faulty button. Any comments or feed back is appreciated.
    Have you tried the button on the side of the machine.
    The two buttons should be in series, so either one can start the machine.
      Yes we did after calming down and remembering there is a button on the side. Thanks
      Qubica BES-X Lane Advertising
      Ball Damage at my wits end
      GS-X table bolts/stud
      Other that...
      1:1 shaft wear
