Brunswick Envoy Duster Cloth is Soaked!!
  • Brunswick Envoy Duster Cloth is Soaked!!
    After running 8 lanes the duster cloth is soaked and not totally sure why. The cleaner jets are flat and not spraying up on to the duster cloth. I'm newer into this side of bowling and just wondering if this can be corrected somehow or should it be soaked when I am done running lanes?
    All help is appreciated and thank you all in advance!
    The duster cloth on our envoy is wet at the end of doing 24 lanes. When our machine was first delivered the tech guy showing us the machine said that is normal. It was wet after doing 2 lanes. Now by soaked are you saying when you stand up the machine the duster cloth is dripping onto the approach? If so I'd say that is excessive. You could check your cleaner pressure with the machine running and make sure it isn't over 20 psi. Ours runs about 18.
    Super Bowl Funday!
    Qubica BES-X Lane Advertising
    Making TDM's adjustable.
