Machine cleaning questions
  • Machine cleaning questions
    Im just curious what you guys do to clean your lane machines inside ? I notice a lot of oil on the wiring harnesses,
    Spray a water based degreaser on a rag and wipe down the inside of the machine on a regular basis. Don't wait till it's a lot of oil or dirt. Follow your machine manufacturers recommendations for weekly / monthly maintenance. A little work now and then can save a big problem later.
      A can of electrical cleaner and compressed air is what you need now. Don't get it in any displays. Then keep it wiped up more often and don't let it get that bad again..
      Super Bowl Funday!
      Qubica BES-X Lane Advertising
      Making TDM's adjustable.
