Cleaner pump output - Kustodian +, Ion, Walker
This is a sticky topic.
  • Cleaner pump output - Kustodian +, Ion, Walker
    Too many people causing confusion with this volume test.
    Battery Machines (Ion, Walker) Test = 25-30mils
    AC machine with AC Cleaner Pump (Kustodian Plus Model A) Test = 25-30 mils
    AC machine with DC Cleaner Pump Test (Kustodian Plus Model B)= 10-12 mils
    AC machine with DC Cleaner Pump (latest Kustodian Plus Model B machines or machines that have load resistor mod fitted to board) Test = 20 mils
    ALL these machines put out the same volume on the lane, it is only the test that differs which is to do with the acceleration curve of the voltage to the pump.
    Mine came factory set at 40. It was running out of cleaner before it could finish all 50 lanes.I brought it down to 30 and noticed I had a few more out of range calls. I set it to 32 and it works great now.
    Table support assembly
    Foul Light LED Mod
