Kustodian Lane machine
  • Kustodian Lane machine
    Lane machine stripper not working. Not putting out cleaner.
    Check the filter inside the cleaner tank. Also the cleaner pumper fuse and fuse holder. If you have an older machine with spray jets, they also have a filter screen inside each one. The pumps do have a lifespan and it may be time to replace it.
    let me be myself
    Pins getting gouged
