Brunswick oil tubing size for Sanction Standard
  • Brunswick oil tubing size for Sanction Standard
    Somebody know where a chart is or just post it here on using Brunswick Logic oil in a Kegel Sanction Standard oil machine oil pressure tubing size for 15 lbs pressure on pump gage at 40.
    All I could find was what was in manual saying 1/4 in tubing 36' long for 40 viscosity. Logic is 43 viscosity. Maybe this has been upgraded ?
Pins getting gouged
