tweek to get scores up
  • tweek to get scores up
    Kustodian lane machine.WIZ plus cleaner 5-1 ratio. 40 mic. Brunswick logic conditioner. 42 ft. pattern. Newly resurfaced wood lanes. Seems like you need to be right on. No forgiveness. Looking for tweeks to improve the scores.
    forward
    01f 2l-2r x 01 00-00 ips 18
    02f 8l-8r x01 00-02 ips 18
    03f 9l-9r x01 02-05 ips 18
    04f 10l-10r x03 05-12 ips 18
    05f 11l-11r x04 12-22 ips 18
    06f 12r-12r x 02 22-27 ips 18
    07f 2l-2r x 00 27-42 ips 30
    reverse
    01r 2l-2r x00 42-37 ips 30
    02r 12l-12r x01 37-34 ips 18
    03r 11l-11r x02 34-29 ips 18
    04r 10l-10r x03 29-21 Ips18
    05r 9l-9r x 03 21-15 ips 14
    06r 8l-8r x02 15-12 ips 14
    07r 7l-7r x01 12-10 ips 14
    08r 2l-2r x00 10-0 ips 14
    Thanks, Joe Wausukee Bowl
    The "old groove" is gone, when you recoat.
    I would wait a bit and give the track a chance to develop again.
    If this is the same pattern you were using originally, I wouldnt change just yet.
    Before and After
    Pins getting gouged
