Our Phoenix won’t disengage any of the solenoids on the right hand side after a new employee knocked the machine over. When we test with a multimeter it has 120 volts going to all of them constantly yet we can’t find any broken wire against the frame or what could be causin this?? Thanks.
Phoenix Model C oil issues.
I'm not familiar with your machine specifically but since your not getting a lot of responses I thought I'd see if I could help you out. Went to the Kegel site and found two manuals for Phoenix model c machines. Once is the Phoenix-S model C which apparently has no solenoids in the machine, It uses a moving oil head to dispense the conditioner across the lane like a printer and motors to raise and lower the other components. The Firebird Phoenix uses wicking pads to dispense conditioner which are controlled by solenoids again with motors to raise and lower other components, So I guess the first thing is to clarify which machine you are referring to. I assume you are talking about the Firebird but I want to make sure we are on the same page.
It sounds like you probably have the Firebird so we'll assume that for now. The manual for the Firebird has had the electrical diagrams removed for some reason but if you have these we can help you resolve the problem. But from what I see this is apparently a PLC controlled machine with each solenoid wired back to the PLC. There is probably a common to all the solenoids and individual control to the solenoids by the PLC.
If I read your posts correctly, the solenoids on the right are energized all the time which keeps the wick pads off the roller and is preventing conditioner to be laid down. So as a work around you have rewired it so the right side is controlled from the left side solenoid control. Is this correct? Did you move each solenoid control on the right to the left side control or was there only one wire that needed connected somewhere?
I'll wait for your response before we dig to deep into this but it sounds like the problem may be in the PLC expansion board but we don't know enough yet to confirm this. If you have wiring diagrams then a very clear picture would be nice to look at or have them scanned to pdf and post here.
Here it is: Get a call from center telling me that the right side 1-5 wick and 5-10 wick solenids will not energize and pull wicks away from silver roller. Solenoids are good...05-21-2011, 06:26 PM
I have a problem with my Phoenix. When I plug power in, the 3rd pad solenoid from the left is energised and pulls the pad away from the roller, and stays that way. It burned out...03-20-2009, 08:54 AM
I havn't had a chance to dig in on this and see what the problem might be. But our two center wicks even tho they are set to go off at the same distance, but one seem to go off...
Channel: Lane Maintenance
11-09-2004, 02:26 PM -
What is the distance ( gap) i should have between the gutter and the roller ? I have a quater of an inch on mine and i'm wondering if this could be my problem ....
...04-14-2011, 06:14 AM -
Hi! NEW today and look forward to Bowl-Tech and what it offers. To start with I am here to ask a question regarding the conditioning we lay at our centre. I am a techician at...09-03-2009, 09:49 PM
Upgraded Motor Contactor
C1 Pinout drawing
Finished the C1 drawing.
Thanks Felix.
If you see any...
Thanks Felix.
If you see any...
