Authority 22 lane conditioner pattern
  • Authority 22 lane conditioner pattern
    Just installed Murrey lanes and need help with oil patterns. Lanes are 6 years old, using Authority 22 lane conditioner, Judge lane cleaner(6-1 mix) in a Phoenix 8 pad machine. Need a starting point as all of my patterns are way to slick.
    Figured 6 patterns.
    MONITOR COLOR ISSUE!!
    Pin spot is off
