Oil to use?
  • Oil to use?
    I have Brunswick synthetic lanes with a Flex oiler. I'm trying to work with Curve lane oil but it is just not working. They say its still dry in the heads and they can't hook their ball into the corner pins. Also alot of carry down. I'm running a 41 foot pattern with 23.4 ml. of oil. Any suggestions on a better oil for these lanes or should I keep trying to tweak my pattern?
    What's your pattern look like?
      How do you get dry heads and too much carrydown?
      23.4ml is alot of oil for a house shot.
      MONITOR COLOR ISSUE!!
      Pin spot is off
