Brunswick Phoneix Lane machine problemm. Help Mee Please!!
  • Brunswick Phoneix Lane machine problemm. Help Mee Please!!
    Hello friends first of all I apologize for my bad english) ,The machine stops early as it comes back as shown in the picture.When the machine returns, the machine finishes the program when the instrument panel is 2.So 5-4-3-2 stopp . There is no problem with the sensor on the side.So there's no obstacle. The counter wheel is counting properly and is in good condition.Normally the machine needs to enter the foul line. I couldn't find the reason. I'll be happy if you can help me. I'd like to give it a try if you tell me what you think.
MONITOR COLOR ISSUE!!
Pin spot is off
