Oil Pattern
  • Oil Pattern
    Hello
    I haven't been on Bowl Tech in years so forgive me if this has been asked a dozen times
    I have a Kegel Walker - AMF Lame Beds and I use Curve Oil
    Does anyone have a Bumper Bowling pattern using my equipment?
    I believe I have a very easy pattern for my bowlers already
    Just asking if anyone has a very Hi scoring house pattern
    Thanks
    Wags
    Wags
    Go to Kegel.net and check out the pattern library.
    let me be myself
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
    1:1 shaft wear
