Kegel Pattern Library and Other References
This is a sticky topic.
  • Kegel Pattern Library and Other References
    PBA Lane Patterns
    Re: Kegel Pattern Library and Other References
    They need to go back a few years and post some stuff for the Phoenix. Alot of centers still run the old bird, still a serviceable and dependable oiler.
      Not much there for infinity/prodigy w/a phoenix-s (c).
      They need MORE patterns for more machines and the newer lane oils.
      Needs updating.
        I have a Phoenix from 1999. Where can I find patterns for it?
          bowl.com has them they also need to be updated seems nobody can take the patterns off the tour and make them available for pad machines?
            which tour patterns are you looking for? I have patterns A,B,C,D,and E for a Phoenix pad
            Cloth: ShamWow!
            Machine: Johnny 5
              Alex can you post them or send them via EMAIL to me. I'm a PBA member and would like to put them in my Phoenix to practice on.
              KWagner1977@msn.com
                Can you send me a heads up if you sent the patterns, I tried to send you a PM but your mail box is full I think.
                  Alex can they work on SB if so please send them to me Thanks Kevin
                    Keith, I sent you the patterns. Sorry it took so long. Thanks for the heads up on my mailbox.
                    Kevin, These setting will not work or AMF/Century machinies but I'll ask around the office to see if anyone has them.
                    Cloth: ShamWow!
                    Machine: Johnny 5
                      Thanks
                        Alex,
                        I would be most greatful if you could send me the patterns also??
                        The conversions for the Pheonix pad machine.
                        Cheers,
                        Alastair
                        (PS. Pheonix model B 7,3,5 tank config, also Pheonix model C with 5 pad set up across)
                          we got one and it is a good peice or equipment (coming from a 30s tech so u might as well say........)
                          Respect is not given freely
                          it must be <span style="font-weight: bold">EARNED </span>
                            I have a question,
                            in our bowling center we have Crossfire kegel machine, and I was unable to find patterns for this machine, can anybody help? I am especially interested in house patterns.
                            Thanks in advance.
                              I was wondering if you could send me those oil patterns too.
                              I would really appreciate it.
                              tstaud42@cinci.rr.com
                              Also, can anyone help. I have had a consistent shot for the past couple of months now all of the sudden - since it has gotten cold and I have turned the heat on - it is not has consistent. Could it be that where I store my machine is not the warmest place? Does that affect the oil in any way? Could it be the heat? I'm at a lose!
                              The New Brunswick NXT
