AS90 scoring issue
  • AS90 scoring issue
    Hello, name is Dave, back ground is one day a week mechanic and I have the most experience....have a pair of lanes that stopped scoring during league....first thought was to check with camera tester... no pins showing either lane....replace CCD processor with a known good one from another pair and the swap kept the other lanes scoring...swapped camera same result.....swapped AS90 Control board still the same....checked 5 volt it is good...only board have not swapped is the AC late ran out of time
    I also will be checking for continuity from the com line from front to back ...did a quick look at cables to see if any cuts but need to look closer tomorrow.
    any suggestions would be appreciated
    I will not see them until later in the day because I'm located in Hawaii
    Thanks from Kauai Bowl on Kauai Hawaii
Haven't actually done any welding for years, so I was up to the challenge when I found this machine that was having problem setting the head pin.
Someone had welded this...
Foul Light LED Mod
