Synthetic panel to low on outsides.
  • Synthetic panel to low on outsides.
    Good afternoon all! Going to have to do some shimming to a lane panel on my lane 53 here. We have Pro Anvilane synthetic panels and during our inspection this year our outsides (7 and 10) on the panel before the pin deck (as i'm told) read -50 so we are 10/1000 off from being at the maximum that the outsides can be depressed. Over the past couple of years it was only the left side of the lane that was slowing going down but now they read this year that both sides are really low. I have a roll of paper and joint sealant (i believe that's what it is) left over from a few approach panels that Brunswick kindly came in and replaced for us as they started cracking, so I believe I can shim the outsides myself and borrow our association's level to check the adjustments, but will I have to break to joint seams to perform the adjustments and have to reseal the joints afterwards? or is it a "simple" mater of just removing lane plugs and unscrewing the panel, sliding the paper shims under and tightening back down with new plugs? I've never had to adjust cross tilts before so as I have an idea I'm unsure of what exactly my process needs to be. Any help/advice would greatly be appreciated! Thank you all for your time!! Have a great rest of the week everyone!
    -Smitty
    Borrow the level first. Check the level yourself at the point they say it's out and several feet up and down the lane. Did they have 5 guys standing one the lane while they checked it? Did they take a wild guess how far from the foul line they were? Assuming they knew what they were doing, you might as well find out how much of the lane is low on the sides and bring a large area back to level while you are there. Now that you have found where the problem is, do you have to move a joint between panels? If not, leave the joint sealer alone. Pop out the plugs, loosen the screws, add shims, tighten screws, check level, repeat until it looks good, install new plugs. I like everything level side to side and zero to .020 up on the sides, but that's just my preference.
    • Carlo
      how to adjust the deppression of a synthetic lane
      by Carlo
      IM new with this synthetic lane and im confused how to adjust the crosswise tilt on the arrow spot by shimming the lane.Can anyone tell me the process putting shim on the depress...
      10-20-2009, 11:36 AM
    • dbd300
      Anvilane problems
      by dbd300
      Here is a problem I'd like to toss out to you guys.
      The center that I bowl at (used to work there; I'm still consulted about this, that or the other) has been experiencing...
      04-11-2002, 10:06 PM
    • Alastair
      protruding shims
      by Alastair
      Have HPL lanes here and the shims used near the foul line have begun to move and stick out the sides of the lane.
      Generally they move to the right side, but some have started...
      07-29-2007, 09:07 PM
    • 1mechanic1
      HPL Lane panels
      by 1mechanic1
      I am not sure if this is a problem or not.....but. My HPL lane panels seem to be separating from each other. The biggest problems seem to be between the 3rd. and 4th. panel, and...
      03-08-2007, 05:20 PM
    • Souljah71
      Lane panels delaminating at panel joints
      by Souljah71
      I am seeing a large number of our lane panels delaminating at the joints. Is there anything i can do to fix this? I have read the article on the "joint sealer" and after...
      07-12-2016, 02:29 PM
    Qubica BES-X Lane Advertising
    Ball Damage at my wits end
    GS-X table bolts/stud
    Other that...
