Trigger sprayer for kegel spot on
  • Trigger sprayer for kegel spot on
    I was wondering if anyone had success finding a trigger sprayer on grainger's site to apply kegel spot on pin deck treatment. My cleaning supply changed their sprayers and the new ones don't work.
    Grainger #41AA37. Takes the work out of it. Clean with alcohol after use as needed.
    Detector Rod Adjustment
    The New Brunswick NXT
