Oilers
  • Oilers
    We are looking into purchasing a new oiler soon. What is best, an Ikon or a Flex? We have a 48 lane center. We don't have to have a walker type.
    We've had the IKON for almost a year now. It's a great machine. If you're upgrading from something like a Kustodian + as we did, the IKON will immediately be familiar, it is mechanically very similar and it uses a lot of the same parts. The key benefits are the battery of course, and the touchscreen which makes it a lot easier to configure and troubleshoot the machine, and you can even program/edit patterns through the touchscreen too. We are a 24 lane center and I believe the battery capacity we have is rated for 54 lanes, so if someone forgets to plug in the charger (which has happened a few times), there should still be enough juice left to get the next league shift covered. If the battery dies, a 10-15 minute charge is enough to finish oiling.
    I think the FLEX is intended for centers that host a lot of competitive tournaments and competitive leagues, and/or feel a need to get incredibly geeky/technical with oil patterns. We only use one type of conditioner, and 2-3 patterns max during any given league season.
      We have the flex and its a great machine, but I would have to side with DBZodos , we spent a lot of extra money on bells and whistle we don't need or use. The dual cleaner and water tanks make it easier for a pin chaser to mix up the two tanks. I had to pump out both tanks cuz one of my guys wasn't paying attention to what he was doing till it was already said and done. I had another guy put water in the oil tanks!!!
      Distributor Clutch Stop Blade Wear
      Replaced this stop blade on an Edge machine at a private installation I service. It looks like this after 20,000 frames. The stop blade on the machine next to it looks new after...
      Qubica BES-X Lane Advertising
      Anyone know if/how to replace the BES-X "station ID" graphic that shows up before and after a video ad runs on the monitors? I'd much rather have it show our logo, especially...
      Ball Damage at my wits end
      We have been getting ball damage on a pair of lanes and we are at our wits end trying to find the problem. Every time we think we have found it we get another ball with damage...
      GS-X table bolts/stud
      I know I'm not the only one who has had the table bolts literally shear off. I cannot explain where there would be a force strong enough to do this to the bolts.
      Other that...
      Preventative Maintenance - Jet Back Booster & A2 Accelerator Control Boxes
      I convert my booster control relays over to Plug-ins as they fail. They are the same as the Motor Start & Recycle relays which makes it very convenient.
      1:1 shaft wear
      Hi all....I have a pinsetter that knocks over pins at times when setting new pins. The moving deck shifts very abruptly right around 270 degrees. Instead of a smooth movement,...
