Broken Lane Near Pin Deck
  • Broken Lane Near Pin Deck
    Here's an issue I inherited from our center previously not having proper capping. Balls would hit the kickback and shoot into the sides of the pindeck causing chucks to be taken out of the end of the lane(pictured). We have this issue on about half of our lanes, some are a little deeper some are a bit shallower. On some of the thicker ones a ball will occasionally be sent flying causing ball damage, so it's not something we can afford to ignore.
    Has anyone encountered something like this before? We're a smaller center so there's no chance of getting entire panels replaced in an option, so any budget fixes would be appreciated.
    http://www.bowltech.com/forum/the-bo...g-lane-removal
    Contact the person who started this thread and see if he has any panels left. From your pic and his pics I think you have the same, but you should confirm before you buy.
      At the very least if you can get a couple of used panels and cut them into shorter pieces you could install them as mini panels. Not the answer you want but I don't believe any repair compound or patch in that area would last.
        We used to call them band-aids.
        Buy one panel, and cut into pieces to match your repair (6-8" long), whatever is needed on each lane.
          Would it be sufficient to cut a 4/1" piece out of the lane, just where it's broken, and replace it with a piece of spare lane panel? or does it need to be cut all the way across?
            The bigger the patch the better, but I would aim to replace a section that goes across the entire lane width, no less than a foot in length in my opinion.
            The edges of the lane are the the most venerable to damage. A small patch on the edge of the lane probably won't last very long and if you attempt to patch the edge pictured there will be very little for it to be screwed in with and will likely never sit properly level with the lane, which will result in poor washing and potential uneven wear in the squeegee of your lane machine.
            • pat
              Does anyone else have this issue
              by pat
              Listed below is a few e-amils that I have been having with Storm Bowling. Storm I do appreciate your fast and professional responses. I am wondering if anyone else feels as...
              02-09-2004, 01:41 PM
            • Adam_Davis
              Pin Deck Installation
              by Adam_Davis
              We have just purchaced 20 Bruns AnvilLane Pin Decks. Here's my question
              I will be doing the installation. I have never done anything like this before, and am a...
              03-22-2001, 12:42 AM
            • TonyP
              Kickback Plates/Pin Deck advice
              by TonyP
              Hello, I am a new member and was hoping that I could pick your brains for information on kickback plate coating and pin deck applications for synthetic pin decks.
              11-27-2000, 01:46 PM
            • msh37ktp
              flying balls
              by msh37ktp
              having trouble with balls hiting the cornners of the kickbacks where the capping ends the kick back is 1/2 an inch over the end of the capping with the corner beaten in, resulting...
              09-28-2012, 02:15 PM
            • Cliff
              ball damage
              by Cliff
              havent solved this one yet. this lane is also the one that cut some real grooves into my ball, unfortanetly no pics of mine.
              im thinking it most likely is in the...
              02-08-2008, 04:07 AM
            MONITOR COLOR ISSUE!!
            Pin spot is off
