Broken Lane Near Pin Deck
  • Kanga (James)
    Originally posted by Bking4242 View Post
    Would it be sufficient to cut a 4/1" piece out of the lane, just where it's broken, and replace it with a piece of spare lane panel? or does it need to be cut all the way across?
    The bigger the patch the better, but I would aim to replace a section that goes across the entire lane width, no less than a foot in length in my opinion.
    The edges of the lane are the the most venerable to damage. A small patch on the edge of the lane probably won't last very long and if you attempt to patch the edge pictured there will be very little for it to be screwed in with and will likely never sit properly level with the lane, which will result in poor washing and potential uneven wear in the squeegee of your lane machine.
  • Bking4242
    Originally posted by Kanga (James) View Post
    At the very least if you can get a couple of used panels and cut them into shorter pieces you could install them as mini panels. Not the answer you want but I don't believe any repair compound or patch in that area would last.
  • Wookie8662
    We used to call them band-aids.
    Buy one panel, and cut into pieces to match your repair (6-8" long), whatever is needed on each lane.
  • Kanga (James)
  • mr.badwrench
    http://www.bowltech.com/forum/the-bo...g-lane-removal
    Contact the person who started this thread and see if he has any panels left. From your pic and his pics I think you have the same, but you should confirm before you buy.
  • Bking4242
    started a topic Broken Lane Near Pin Deck
    Here's an issue I inherited from our center previously not having proper capping. Balls would hit the kickback and shoot into the sides of the pindeck causing chucks to be taken out of the end of the lane(pictured). We have this issue on about half of our lanes, some are a little deeper some are a bit shallower. On some of the thicker ones a ball will occasionally be sent flying causing ball damage, so it's not something we can afford to ignore.
    Has anyone encountered something like this before? We're a smaller center so there's no chance of getting entire panels replaced in an option, so any budget fixes would be appreciated.
  • pat
    Does anyone else have this issue
    by pat
    Listed below is a few e-amils that I have been having with Storm Bowling. Storm I do appreciate your fast and professional responses. I am wondering if anyone else feels as...
    02-09-2004, 01:41 PM
  • Adam_Davis
    Pin Deck Installation
    by Adam_Davis
    We have just purchaced 20 Bruns AnvilLane Pin Decks. Here's my question
    I will be doing the installation. I have never done anything like this before, and am a...
    03-22-2001, 12:42 AM
  • TonyP
    Kickback Plates/Pin Deck advice
    by TonyP
    Hello, I am a new member and was hoping that I could pick your brains for information on kickback plate coating and pin deck applications for synthetic pin decks.
    11-27-2000, 01:46 PM
  • msh37ktp
    flying balls
    by msh37ktp
    having trouble with balls hiting the cornners of the kickbacks where the capping ends the kick back is 1/2 an inch over the end of the capping with the corner beaten in, resulting...
    09-28-2012, 02:15 PM
  • Cliff
    ball damage
    by Cliff
    havent solved this one yet. this lane is also the one that cut some real grooves into my ball, unfortanetly no pics of mine.
    im thinking it most likely is in the...
    02-08-2008, 04:07 AM
Bind in deck hook linkage
I'm having a problem with the deck holding hook lifting up and not engaging the pin during 2nd ball cycle. At first, I thought it was the detector but have ruled that out. If...
GS-X table bolts/stud
I know I'm not the only one who has had the table bolts literally shear off. I cannot explain where there would be a force strong enough to do this to the bolts.
Other that...
Not scoring when ball speed "ball detection" is enabled
I have a pair that won't score if ball detection is turned on, but when I turn it off the scoring works right away.
On the ball speed sensor, the green light indicates...
GSX pins dumping in table at front
Hi everybody, I'm looking for some guidance. My GSX machines have a problem with pins gathering in the table in front of the #3 pinholder. One or two lanes are worse than the...
Idler shaft
One of our lanes has a bad bearing assembly for the distributor pulley. The idler shaft that the pulleys sit on has been damaged where it sits on the bearing. I took the assembly...
