Hpls
  • Hpls
    Just a comment wear when the weather gets cold cpl of my lanes get the bowl effect more and have water spots after strip. Summertime I don't but now i'm starting to again. From N.mich.
    Lane panels expand and contract under heat and cold like anything else. Worked a center once, here in Arizona, that had a couple of panels that bowed so much in cold weather that the lane machine buffer wouldn't even touch the lane surface, leaving a bare spot.
    Your only remedy is going to be to shim the panel, and make sure all the screws are secure.
    -- Larry
    • Shannon
      Rock n Bowl
      by Shannon
      just a caustion to all centers. We currently just installed new lanes in our center and the installer informed us that we cant use the "Rock n Bowl" slogan, cuz someone...
      07-09-2000, 12:49 AM
    • the old dirt man
      lane condition's
      by the old dirt man
      with all the bowler's that like to whine and whine,because they can't stand in the same spot week after week,I think we should change the shot every week,then mabe they would...
      03-05-2001, 02:55 PM
    • John_Galt
      Karaoke on the lanes
      by John_Galt
      I've seen many places implement short-term karaoke in a separate bar with good success - short-term.
      Have heard about karaoke on the lanes, made possible via wireless microphone,...
      12-22-2004, 05:41 AM
    Bind in deck hook linkage
    GS-X table bolts/stud
    Other that...
