Kustodian+ Cleaner Tank
  • Kustodian+ Cleaner Tank
    My Kustodian has developed a leak near the cap of the cleaner tank for the second time.
    The first time, I was able to heat the glue that secures the fitting to the tank. This time, I can't get it to seal.
    I don't think silicone will work, I don't think it will stick to the plastic very well. Any suggestions on a glue that you could heat and blend in?
    Re: Kustodian+ Cleaner Tank
    I gave up, I can't get it to seal...
    I ordered a new one $225.00 for the tank only.
      WOW.... $225.00 for a new plastic tank...
      Must be Kegel is buying alot steak sauce for Alex, or was that hot sauce..
      Just playing Alex,
      Been awhile, had to bust them.
      Mike
        Wouldn't some 2 part epoxy work?
        If at first you don't succeed...get a bigger hammer!!!!
        American and proud of it
          I got the new one in today...
          Maybe I could sell the old one for half price [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_lolol.gif[/img]
            Yes the silicone will work, I did the routine maintenance on our machine and had to clean out the filter. Just give it 24 hours to set.
              I have always kept an extra tank as it is a PITA trying to patch one and most of the time you notice it when you need it not when your done.
              Drill
              David Bolt
              Champaign, IL
              USBC Silver Coach
              IBPSIA BOD
              IBPSIA Advanced
              Technical Certified
              Pro Shops
                Saves on overnight freight charges too! [img]/content/btubb/images/%%GRAEMLIN_URL%%/icon_curse.gif[/img]
                  i had a crack in the top of my tank. i used
                  two part epoxy to seal it. that was over a year ago.
                    Yes, after paying for the first one overnight and on a Saturday delivery due to a tournament I will not go with out an extra one again.
                    Drill
                    David Bolt
                    Champaign, IL
                    USBC Silver Coach
                    IBPSIA BOD
                    IBPSIA Advanced
                    Technical Certified
                    Pro Shops
                      How did the tank crack? I have been working for a short period of time as a mechanic (6 years) and have never heard of one cracking. Was it old or was it dropped or damaged by someone? Just curious.
                      Qubica BES-X Lane Advertising
                      Ball Damage at my wits end
                      GS-X table bolts/stud
                      Other that...
