Laminate separating
  • Laminate separating
    I have HPL synthetic lanes and I am starting to have trouble with the laminate separtaing from the wood that it is attached to. I have one lane in particular that has separated a good 15-12 inches. Does anyone know if the laminate can be reattached as I am thinking that it can't be because of all the chemical build up in the wood. To make matters worse the wood is splitting about a 1/2 inch from the laminate. This is causing the section to be too high at the joint and it is chipping away at the bowling balls. The worse part is the problem are is right in the middle, so there is really no way around it.
    Steve Heitman
    Re: Laminate separating
    Purchase replacement panels and seal the joints after installation and leveling.
      I agree with King. I’ve tried almost every epoxy on the market without success.
      One thing I would like to add… is before installing….seal the end edges and dowel holes with a couple “light” coats of urethane (don’t get to much in the dowel holes). That way when (not if) your seam sealer comes loose, cleaner and oil won’t penetrate the pressboard.
        It can be mended - not fixed. It involves raising the delaminated panel, drilling 7/64" holes throught the top or bottom into the space about 2" from the edge, injecting the DBA inject-a-patch into the drilled holes and clamping the panel with angle iron for an hour. Trim off the epoxy that exuded from the gaps, and re-screw the panel down, checking the flat/level/joint difference and shim accordingly.
        In the heavy oil lane area, it's harder to get a permanent fix as the delaminated area has some lane conditioner in it. Impossible to clean out.
        I've been able to effect a long term fix on Brunswick pin decks with this method, but any oiled lane panel - I wouldn't guarantee.
          QAMF no longer makes HPL panels. but SPL panels are available. they look identical. mirror image. price and weight however are not mirrored to eachother.
          check and see if you are still in warranty. 5 year warranty i believe on the panels.
            Ted,
            I have tried the exact method you described except I drilled 1/8” holes and did not use the DBA product. Is it more flexible?
            All my delaminating (so far) has occurred at the fouline where oil and cleaner is not a big problem. I could get the mend to hold for a few weeks but then it would delaminate worse. I’m assuming this is because of balls being dropped there (and the shims underneath creating a void quite a few inches from the line).
            On one panel, I tried a more flexible epoxy from Grainger that did not last any longer than the many other epoxies I tried. Have you had success at the fouline? I’ve even extended the width of the shims underneath (including creating more of a taper to reduce the void) and this did not help.
            I should also mention, that I did use a glue syringe to eject the epoxy…maybe it wasn’t enough force.
              I have seen this many times on service visits here in Europe & having seen many bodge up repairs too i tend to agree with king & triac that new panels is the only way. However i admit i have never tried to repair them myself.
              Triac- i like your idea for sealing the edges before installation - simple but effective.
              Geoff.
                we had that very problem with murrey pathfinders.bout
                pulled out my hair dealing with that!
                  Oh if we only knew in 1979 what we know in 2009.
                    Originally posted by triac
                    Ted,
                    I have to admit, I haven't tried it at the foul line. I can tell you though, there should be NO shim under the panel in the first 10' to 12' of the head. There will always be cracking on the bottom where ever there is a piece of shim paper, and many times it comes through to the top.
                    I would try it there though. The DBA stuff is indistinguishable from the AMF as far as I could tell using both for many years. It does not get as brittle as other true OTC epoxies. But it will not displace oil that may keep penetrating the substrate.
                    At the foul line, repairs are ugly. Looks like a repair job. I'd still try it until I got a few to replace.
                      Unfortunately our synthetic lanes were installed 3-4 years before I got here and that was 13 years ago. We kept our wooden approaches so the drop from the foul line has been up to 0.180” on some lanes.
                      That’s the way the installers did it and we also have thin shims on the sides for cross tilt under the head section.
                        We kept our wooden approaches so the drop from the foul line has been up to <span style="font-weight: bold">0.080”</span> on some lanes.
                        Oops.. <span style="font-weight: bold">Fixed</span>
                          If you are starting to see this on a few panels, I would start looking at the rest of the panel joints in your center. You will no doubt find that your "filler" is gone. You should start a project of cleaning out the panel joints and applying a new "filler". I use marine adhesive instead of the more popular silicone as the adhesive lasts much longer.
                            Will the SPL panels delaminate like the HPL panels?
                              It is not likely that the SPL panel will delaminate. There is a fundamental difference in laminating 3 pieces of material together with a glue (HPL) and a full thickness single laminating process (SPL). Like others on the market, the entire panel is laminated in a single heat/pressure process so the end product is fully manufacturered by a single lamination. HPL is 3 independant layers sandwiched into a single panel and dependant on the effectiveness and integrity of the sandwiching process. This is the issue AMF dealt with for a few years after they decided to sandwich these layers themselves in Richmond. When Wilsonart made the complete panels for them, they had a long manufacturing history of the process and the 3 layers performed well. Then, to reduce costs, AMF decided they could put these layers together and bought the equipment to do it - then had a learning curve about the process and had issues with the layers coming apart. Later, the panels didn't delaminate. Problem was, no one else in the whole world (other that your center) had the problem. but, the word got around, even AMFs own centers had the problem but weren't on the list of centers to visit to see the product.
                              Now, SPL is the product. Just like Brunswick Prolane, Anvilane, Murray, Xima, VIA, Switch and others, the laminate is made in a single process and will NOT likely ever come apart. I placed a single process laminate piece in a glass of water for months and I swear, it mic'd thinner than when I put it in!
                              So, what you are buying is what ever the salesman convinces you is the best. A glow pattern, a surface marking pattern, a thickness or whatever......
                              • Souljah71
                                Lane panels delaminating at panel joints
                                by Souljah71
                                I am seeing a large number of our lane panels delaminating at the joints. Is there anything i can do to fix this? I have read the article on the "joint sealer" and after...
                                07-12-2016, 02:29 PM
                              • Alastair
                                protruding shims
                                by Alastair
                                Have HPL lanes here and the shims used near the foul line have begun to move and stick out the sides of the lane.
                                Generally they move to the right side, but some have started...
                                07-29-2007, 09:07 PM
                              • tallrick
                                Fixing wood lane gouges
                                by tallrick
                                I am making repairs to the lanes damaged in 2004, and while the lanes are pretty much flat and level now, there are scratches and gouges where the roof trusses had fallen on the...
                                11-12-2006, 02:17 AM
                              • tallrick
                                fixing gouged wood
                                by tallrick
                                Would it be possible to repair a long scrape in a lane by filling it with sawdust and phenolic resin, then pressing and heating it, before the final sand and finish? I have a...
                                06-07-2007, 02:12 PM
                              • Adam_Davis
                                HPL or AnvilLane
                                by Adam_Davis
                                This one may stir up a little controversy.
                                Which lane surface do you prefer? HPL or AnvilLane?
                                I finally talked the owners out of Guardian. (I...
                                04-05-2002, 01:51 AM
                              Qubica BES-X Lane Advertising
                              Ball Damage at my wits end
                              GS-X table bolts/stud
                              Other that...
