help with oil pattern
  • help with oil pattern
    Hi! I am new to the forum. Looking for some help with my oil pattern.
    I help run a small 6 lane house. we use a kegel crossfire pad machine.
    They are wood lanes. fully resurfaced 2 years ago.
    The pad setup is 7,3,5,5,5,5,3,7. We use navigate oil by kegel.
    I am just looking for the shot to be a little more playable.
    Right now it is very over under and very speed sensitive.
    Here is the current patteren i am running.
    Any help would be great.
    Thanks!
    Start Cleaning Distance 0
    Oil Only Dust(yes=1/no=0) no
    Oil Distance (Feet) 39
    Forward Shift To 2nd (Feet) 18
    Forward Shift To High (Feet) 39
    Zone 1 Pads Off (Inches) 18
    Zone 2 Pads Off (Inches) 72
    Zone 3 Pads Off (Feet) 34
    Zone 4 Pads Off (Feet) 34
    Fwd Buff Distance (Feet) 39
    Reverse Shift To 2nd (Feet) 39
    Reverse Shift To Low (Feet) 18
    Drop Brush In Reverse (Feet) 37
    Zone 4 Pads Off (Feet) 36
    Zone 3 Pads Off (Feet) 36
    Zone 2 Pads Off (Inches) 180
    Zone 1 Pads Off (Inches) 24
    Reverse Buff (Feet) 0
    i would ask the lane king he is the best
      I'd start by increasing the distance a few feet.
        39 feet is very short for wood. As Jack_Sparrow suggested go a little longer.
        let me be myself
          Steve Cross at Kegel is your man 800-280-2695
          Pins getting gouged
