Kegel Elite lane machine oil pattern's
  • Kegel Elite lane machine oil pattern's
    Look for a good oil patter that will work on the Kegel Elite at the time we are using Kegel high street. the issue i am having with all the lane pattern is no matter what we try the oil never seems to be outside of the ten board it's all in the middle. just looking for some good info thanks.
    Copy the program to another slot, and make pattern changes to suit your house.
      That's really where you want it. That's pretty much the "standard blocking" of the lanes we've used for years. I believe you need just 3 units outside the 10 and 30 boards so if you have that, you're good. Much better scoring this way, more scores, more drinks, more money.
      Before and After
      Pins getting gouged
