pattern help
  • pattern help
    Kustodian lane machine.WIZ plus cleaner. Brunswick logic conditioner. 42 ft. pattern. seems like you need to be right on. No forgiveness. Looking for tweeks to improve the scores.
    forward
    01f 2l-2r x 01 00-00 ips 18
    02f 8l-8r x01 00-02 ips 18
    03f 9l-9r x01 02-05 ips 18
    04f 10l-10r x03 05-12 ips 18
    05f 11l-11r x04 12-22 ips 18
    06f 12r-12r x 02 22-27 ips 18
    07f 2l-2r x 00 27-42 ips 30
    reverse
    01r 2l-2r x00 42-37 ips 30
    02r 12l-12r x01 37-34 ips 18
    03r 11l-11r x02 34-29 ips 18
    04r 10l-10r x03 29-21 Ips18
    05r 9l-9r x 03 21-15 ips 14
    06r 8l-8r x02 15-12 ips 14
    07r 7l-7r x01 12-10 ips 14
    08r 2l-2r x00 10-0 ips 14
    Thanks, Joe Wausukee Bowl
    forgot to say newly resurfaced wood lanes. Thanks, joe
      I have Wood lanes with Guardian overlays on the heads. I use oxyshock cleaner and curve oil. I run this pattern and it's pretty forgiving for us.
      40 ul 43ft reverse drop brush 36ft 25.08ml
      2-2 2 14
      7-7 1 18
      9-9 1 18
      10-10 4 18
      11-11 4 18
      12-12 2 18
      2-2 0 26
      reverse
      2-2 0 26
      12-12 3 18
      11-11 4 14
      10-10 4 14
      9-9 1 14
      8-8 2 10
      2-2 0 10
      Looks like with you running just one 2-2 pass that it would have quite a bit of bounce if you miss right. if you try it out let me know how it goes.
      Before and After
      Pins getting gouged
