Need a pattern tweak
  • Need a pattern tweak
    Kustodian
    Hv offense oil
    Defense C stripper 4 to 1
    HPLs
    40ul oil dail set
    First game great then lanes go to over and under and lose some backend.
    F
    2 - 2 2 14 40'
    7 - 7 2 18
    9 - 9 2 18
    10 - 10 3 18
    11 - 11 4 18
    12 - 12 3 22
    2 -2 26
    R
    12 - 12 2 22 37'
    11 - 11 3 18
    10 - 10 3 18
    9 - 9 3 18
    8 -8 3 14 8'
    2 - 2 0 10
    Would think Remove 8-8 R to clean off brush more and take out 2 loads on F ?
    Well seems to me when I put your #s in KOSI to much oil and applied to far foreword and reverse.While I don't have HPL I wrote a pattern for a guy who does and he has had good success with it and also bowl on it in a different house. This is how I would tweak what you have.
    HPL TWEAK
    2-2 2 10
    7-7 1 18
    8-8 1 18
    9-9 2 18
    10-10 2 18
    11-11 3 18
    12-12 2 18
    2-2 0 22 42 FT
    REV 37
    2-2 0 30
    13-13 2 18
    12-12 3 18
    11-11 3 18
    10-10 3 14
    9 - 9 2 14
    8 - 8 1 14
    2 - 2 0 10
      Ok Thanks. What kind of oil is your buddy using ?
        I think it was/is Infinity.
          37 vis compared to O HV 50 vis 42’ may have to go to 40’ ?
            So the pattern tweak I suggested was based on your pattern along with the oil and cleaner you are currently using. The change from 40 to 42 was because of the oil volume change , difference in taper and my own experience bowling on HPLs. Not sure at this point if it's a good idea to make changes to your conditioner or cleaner because to many changes at once can make things confusing for you and your bowlers.
              Just need to add oil to outside, said to dry. So im assuming a 7-7 or 8-8 load on forward only ?
                Post your pattern with the changes you have made.
                  Its in above post By HEADWEST Have not changed anything.
                    here it is
                    HPL TWEAK
                    2-2 2 10
                    7-7 1 18
                    8-8 1 18
                    9-9 2 18
                    10-10 2 18
                    11-11 3 18
                    12-12 2 18
                    2-2 0 22 42 FT
                    REV 37
                    2-2 0 30
                    13-13 2 18
                    12-12 3 18
                    11-11 3 18
                    10-10 3 14
                    9 - 9 2 14
                    8 - 8 1 14
                    2 - 2 0 10
                      here it is
                      2-2 2 14
                      8-8 2 14
                      9-9 3 18
                      10-10 3 18
                      11-11 2 18
                      12-12 1 18
                      13-13 1 18
                      2-2 0 22 42FT
                      I would try changing my forward loads to this. The HPLs that I've bowled on seem hook early in the track.After giving it a try and you want more out you could change the 8-8 to a 7-7.
                      Detector Rod Adjustment
                      The New Brunswick NXT
