pattern tweak
  • pattern tweak
    posting for another center.
    have a kegel ion
    brunswick prolane
    kegel fire lane oil
    jayclean mixed 4:1
    # start-stop load sp
    1 2-2 1 14
    2 10-10 3 18
    3 13-13 3 18
    4 2-2 0 18
    5 2-2 0 22
    6 2-2 0 30
    foward distance 40 ft
    reverse distance 35 ft
    1 2-2 0 30
    2 14-14 2 18
    3 13-13 4 18
    4 12-12 4 14
    5 11-11 2 10
    6 2-2 1 10
    7 2-2 0 10
    what is going on is they are getting lots of carry down. lots of spinning balls, out of ranges and pins sliding all over the deck. the backends are playing weak and not much snap off the outsides. any help would be greatful
    thanks
    Very first thing to do verify that the lanes are getting clean. No film, no oil... nothing left on the lanes. Start from there. and post back.
    let me be myself
      Also need to check the cleaning distance. If it stops cleaning just at the end of the pattern there might be a problem too.
        What volume is being used? The 7 forward loads are not consistant with the problems they are having. Also, too much/too strong cleaner leads to oil migration.
          It is definitely a cleaning issue. I would dilute the cleaner to 8 to 1 and note the change.. it is too strong and leaving a film
          Chris Doughten
          Lodge Lanes, Belleville Mi
          • JulianD
            OOR issues!
            JulianD
            I've been getting a lot of OOR's. I've try to adjust the last squirt distance on the oiler(Kegel ION) to about 58' I wanna say. I was wondering what your guys settings are for...
            02-05-2013, 10:19 AM
          • Beavis834
            Looking for a pattern tweak
            Beavis834
            Lane Machine: Ion
            Surface: Pro Anvilane
            Oil: SynPro 40
            Cleaner: Defense C 4 to 1
            Here is my pattern:
            50 mic stream
            42'
            12-09-2009, 11:36 PM
          • Dkef150hd
            PLEASE!! HELP WITH PATTERN
            Dkef150hd
            I NEED HELP WITH PATTRN HAVING A LOT OF 10 PINS AND 7 PINS LEFT.IM RUNNING KEGEL MAIN STREET PATTERN.IM USEING A ION MACHINE,DEFENSE-S CONDITIONER,DEFENSE-C CLEANER 4:TO1 MY LANES...
            12-06-2012, 08:12 AM
          • Carman
            pattern help
            Carman
            ive been getting feed back on the lanes hook to much. that the down and in players cant keep the ball on the right side.
            this is what im running:
            i have a 6 month...
            10-26-2011, 12:00 PM
          • ColJim
            I can't believe it
            ColJim
            I have a scratch league that started in September . We have been using the same pattern since the 4th week of the season . We've had a lot of honor scores since then . About 4...
            05-16-2014, 05:50 PM
          Detector Rod Adjustment
          The New Brunswick NXT
