Looking for an oil/oils to replace Fire and Ice combo on ProAnvilane
  • Looking for an oil/oils to replace Fire and Ice combo on ProAnvilane
    We got a Flex machine last year and still trying to find a playable shot for all players. We have the 1st generation of ProAnvilane. The guys with allot of speed are scoring well but the slower ball speed guys are struggling. Balls are hooking up early and roll out before the pocket.Thinking of going to a lower viscosity oil with more surface tension. Thanks allot,Sid
    My center switched from fire and ice to just ice and added volume to our pattern. We also made our pattern 50mics instead of 40. Post your pattern and someone with more pattern design knowledge will help you out.
      We use Offense HV with the same lane surface you have, but in a Kegel Elite machine, with Defence C cleaner
      IT IS BETTER TO APPEAR STUPID, THAN TO OPEN YOUR MOUTH AND REMOVE ALL DOUBT!!!
      Before and After
      Pins getting gouged
