pin damage
  • pin damage
    strange scratches on the sides on my pins. what could cause that? top of the belly and below the neck.
    <---- You are getting sleepy, very sleepy. When you wake-up you will want to bowl more. . . .
    Look at the pin guides for burrs
      okay. will do
        AMF or brunswick machine ??
        "Don't expect too much and you'll never be let down..."
          Profile indicates Brunswick A's
            Ours get that way from getting stuck under the ballwheel guards...especially if they're OEM and installed backwards...if the guard is flipped to the opposite side, the rolled edges are sharp...facing in towards the pit...
              Ours were getting them from metal turn pan cams and damaged scissors.
              "Penny for your thoughts" and you give them "Your two cents"...... Do they owe you change?
              The New Brunswick NXT
