cap lighting from The Lighting store
  • cap lighting from The Lighting store
    I purchased cap lighting in 2011 from the C.J. Fox (The Lighting Store). I know that C.J is no longer with us, and the business has closed. I'm looking for someone who might have purchased led cap lighting from his store. The lights are 40" long and can be connected together via a 5" white wire. I'm looking for replacement and can't find anything about them as far as a brand name or where they were made. Any help would be great.
    Look at the power supply/controller box...Thats where you should find the info
    "Don't expect too much and you'll never be let down..."
      no controller box, plugs directly into 110v
      Detector Rod Adjustment
      The New Brunswick NXT
