Lightworx Don't Flash
  • Lightworx Don't Flash
    I have a lane where all the lights light but don't blink. Have replaced 1st light module, address decoder, transformer and cable from address decoder to 1st light module with no change. Please help. All parts replaced were new. Cable was just run between address decoder module and 1st light module on top of lane not through the underground.
    It's a PITA but I'd suggest firstly wiggling each plug to each light module. If that doesn't affect the problem, get a spare light module and cable and bypass each light module one at a time.
    Pins getting gouged
