Lightworx LED Pin Light
  • Lightworx LED Pin Light
    Hello all, I have the Brunswick lightworx pin deck lights. We use those all the time. We are hoping to get a tournament there. Does the lightwork have a "white" setting? Or am I going to have to get the original pin deck fixtures working again?
    If the same thing happens more than once, You got a problem
    Although my center does not have the lightworx Pin lights, I thought I might share.
    Don't the lightworx fixtures run on DMX control?? If so, you can simply adjust them to white with your controller.
      http://www.brunswickbowling.com/prod...e-accessories/
      The New Brunswick NXT
