telescores-screen malfunctions
  • telescores-screen malfunctions
    I have an overhead monitor that 3/4 of the screen is blurred. I have switched the connections with the unit right beside and everything works fine. Have switched out all the circuit boards, but still does not fix the issue. Help?
    Your profile says you have Vector scoring. You might want to post this question there since it's not a telescore question. This pic is a telescore. Bowlers write scores on clear plastic and light shines through it and projects on a screen.
      Ah the good old days, sharpen chinograph pencils and change the bulbs, sorted!
        And if it was a morning league, you could also cook your bacon & eggs on the glass. Later leagues, burgers.
        Before and After
        Pins getting gouged
