Led bulb size for masking unit
  • Led bulb size for masking unit
    Does anyone know what size led bulb will go into Star Shiels
    masking units. The bulbs have a 1/2” base with the two little dots on the base and the 2 little studs on the side.
    There should be a part number printed or stamped in the base.
    Super Bowl Funday!
    Qubica BES-X Lane Advertising
    Making TDM's adjustable.
