Having a problem with ball accelerator. It will not start when you turn the machines on. I have replaced both relays but still have nothing. If I plug motor into an extension cord, the motor runs fine. Any help would be greatly appreciated.
Ball Accelerator not working
The motor won't start with either machine of the pair on? A couple of things to check. First one, are the cannon plugs that supply the 24V for the relays connected to the electrical box? I have disconnected one or both of those before when doing certain maintenance on machines and have forgotten to connect 'em when I finish. The other is to make sure that you're getting voltage to the accelerator motor through the drop cord from the ceiling. That power is usually on a separate circuit from the pinsetters and there should be circuit breakers for the accelerators in one of the distribution panels in the service aisle. As stated above, use a meter to do some of the troubleshooting.It is wiser to find out than suppose.--Mark Twain
GuestWe are having a problem with or ball accelator. We have power going to the box just behind the accelerator motor. We just replaced the relay in that box and resottered ect....
Channel: Pinsetters Brunswick A-A2
07-27-2000, 01:42 PM -
Last night I was trying to get a pair of lanes going that have been down a while. From what I understand an electrician had been in and somehow messed things up after trying to...
12-11-2017, 09:38 AM -
alright, so i had a ball accelerator motor go out the other day. pulled it and put in our only spare, got the wiring into the motor right but in my haste i didn't check the rest...
06-12-2009, 10:50 AM -
hey guys. I had my mechanic replace the a relay in my acc. control box. I came in this morning & turned on the power switch for the control box & the accelerator...
01-29-2010, 09:59 AM -
Hi guy`s ive just changed a ball accelerator motor after it stoped working and now it seems to be running all the time as soon as i start up a machine. its not stoping after it...
Channel: Brunswick GS Pinsetters
01-29-2012, 02:13 PM -
Upgraded Motor Contactor
C1 Pinout drawing
Finished the C1 drawing.
Thanks Felix.
If you see any...
Thanks Felix.
If you see any...
