Ball Accelerator not working
  • McTim
    started a topic Ball Accelerator not working
    Having a problem with ball accelerator. It will not start when you turn the machines on. I have replaced both relays but still have nothing. If I plug motor into an extension cord, the motor runs fine. Any help would be greatly appreciated.
  • McTim
    It ended up being a bad breaker on the wall. It was weird because it's the same breaker for the machine and ball accelerator, and the machines were working fine. Thanks for the help.
  • Stripperbolt
    The motor won't start with either machine of the pair on? A couple of things to check. First one, are the cannon plugs that supply the 24V for the relays connected to the electrical box? I have disconnected one or both of those before when doing certain maintenance on machines and have forgotten to connect 'em when I finish. The other is to make sure that you're getting voltage to the accelerator motor through the drop cord from the ceiling. That power is usually on a separate circuit from the pinsetters and there should be circuit breakers for the accelerators in one of the distribution panels in the service aisle. As stated above, use a meter to do some of the troubleshooting.
  • PJ
    The power for your front relays starts in the back. check and see if they work. sometimes the connector on accelerator box gets loose.
  • mr.badwrench
    It sounds like there is no power to the relay box for the relays to switch. You need a meter.
Upgraded Motor Contactor
Hey all. Just had a motor contactor go on one of our machines. I remember seeing new cube relays or solid state contactors we could replace them with. Anybody got a part number...
C1 Pinout drawing
Finished the C1 drawing.
The base for this came from a drawing made by Felix dated 2006.
Thanks Felix.
If you see any...
CCD Processor Move by Masternut
These are pictures submitted by "MASTERNUT" of a project in his bowling center where he moved his CCD processor boards from the location on the capping to the curtain...
