accelerator relay wire size?
  • accelerator relay wire size?
    Having the accelerator relays, I need the wire size so I can pre solder a few of them.
    Also...what is the wire size from the pinsetter to the ball lift..i may need to run new wires. I have a lift motor that shuts off by itself OR something is making it shut off like a bad wire or ??. Wires in back look fine.
    To go from accelerator to ball lift, all you need lamp cord or extension cord, low voltage. 18 gauge should do.
      If I remember correctly, all wires in booster/accelerator/lift boxes are 16 gauge.
      External 24 volt control wires are 18 gauge zip cord.
      https://www.1000bulbs.com/product/88...bT8aAn8g8P8HAQ
      The New Brunswick NXT
